wlan-qos-policy
Configures a WLAN QoS policy and
enters its configuration mode
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
wlan-qos-policy <WLAN-QOS-POLICY-NAME>
Parameters
| <WLAN-QOS-POLICY-NAME> |
Specify the WLAN QoS policy name. If a policy with the specified name
does not exist, it is created. |
nx9500-6C8809(config)#wlan-qos-policy test
nx9500-6C8809(config-wlan-qos-test)#?
WLAN QoS Mode commands:
accelerated-multicast Configure accelerated multicast streams address and
forwarding QoS classification
classification Select how traffic on this WLAN must be classified
(relative prioritization on the radio)
multicast-mask Egress multicast mask (frames that match bypass the
PSPqueue. This permits intercom mode operation
without delay even in the presence of PSP clients)
no Negate a command or set its defaults
qos Quality of service
rate-limit Configure traffic rate-limiting parameters on a
per-wlan/per-client basis
svp-prioritization Enable spectralink voice protocol support on this
wlan
voice-prioritization Prioritize voice client over other client (for
non-WMM clients)
wmm Configure 802.11e/Wireless MultiMedia parameters
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
| no
Removes an existing WLAN QoS POLICY |
For more information on WLAN QoS
policy commands, see
WLAN-QoS Policy.
